Best buy 15" LCD?
Q
QuQ
I'm looking for a 15" LCD Screen for my DVD player. I have a budget of about £150. Any recommendations. UK, if that makes any difference.
Thanks,
QuQ
RockySpieler
Established Member
No idea on the best, or cheapest, just that I suggest you go for a widescreen version (you may have to jump to 17" to find Widescreen versions), because anamorphic DVD will look tiny on a 4:3 ratio 15" screen.
Ensure the TV has component input..........hopefully your DVD Player has this output (or RGB scart......or S-Video.....listed in pq order).
Gaming:-
Also if you intend to get a Wii go for SD resolution, or XBox360 go for a HD resolution version (Not HDReady......just HD input via VGA).
Other factors:-
Intergrated frreview....maybe worthwhile
Intergrated DVD.........probably not worth it, unless you are very tight for space, like caravan / kitchen etc.
Check these sites regularly for special offers:-
http://www.hotukdeals.com/main.html
http://forums.moneysavingexpert.com/forumdisplay.html?f=36
Also check Currys/Dixons adverts........plus Supermarkets, Asda, Sainsbury's have LCD ranges, sometimes on special offers. And the Supermarket returns policy is normally excellant.
Q
QuQ
Thanks for the replies. RockySpieler, are most DVDs anamorphic or what? Cosmos, thanks too, i'll take a look in those shops aswell.
edit:
i'm only gonna use it for DVDs, and I have the player, so I actually only need the screen.
RockySpieler
Established Member
If you see black bars at the bottom and top then your DVD's anamorphic.
Generally film DVD's are anamorphic, and recent TV-Series DVD's are 16:9 widescreen. But I do have a US R1 Monster Inc which is 4:3 (price was cheap, and I didn't read the advert properly.........:suicide: ).
If you have any favourite films, check the back of the cover 2.35:1 is anamorphic (black bars top/bottom), 1.78:1 (can be different, 1.75,1.88 etc) is 16:9 widescreen, 1.33:1 is 4:3 non-widescreen.
I prefer to watch everything in its orginial format, whether that be 1.78:1 for TV Series (or 1.33:1 for classics), or Films at 2.35:1. I think you can even get wider aspect ratio's............I'm not that much of an expert on DVD's.
Just noticed that my "A bug's Life" DVD is a flipper 4:3 (1.33:1) on one side, and 2.35:1 (anamorphic) on the other.
Some Maths............
15" 4:3 Ratio TV
TV Diagonal 15"
TV Width 12"
TV Height 9"
2.35 Height 5.1"
16:9 Height 6.75"
15" 16:9 Ratio TV
TV Diagonal 15"
TV Width 13.07"
TV Height 7.35"
2.35 Height 5.56"
16:9 Height 7.35"
The 16:9 15" TV is basically 1/2" higher and 1" wider than the 15" 4:3 Ratio TV when watching widescreen images. But personally I would go for 17" widescreen.....worth saving a few more weeks, and you could get one in the Christmas / New Years Sales. Widescreen is more future proof, quite a bit of TV is now broadcast in 16:9 thesedays.
Q
QuQ
Ok, thanks for the reply again. I'm pretty sure most of my DVDs are anamorphic in that case. This just a bedroom system, so it may not be so bad, but i'll take a look at 17" screens too.
Thanks,
QuQ
dan54
Established Member
Ive just gone against all my better judgements and lecturing other people "you get what you pay for" and "dont ever bother with an indoor aerial" and gone and bought a 15" Mogen lcd with free freeview box from sainsburys for £130 for 'er indoors for the bedroom.Now I've gotta admit its pretty good!!-It aint gonna win any awards from Home Cinema Magazine but for £130 I reckon its a bargain.
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
