Best 'Budget'1280 x 720 (16:9) projector ?
Discussion in 'Projectors, Screens & Video Processors' started by Mr Sparkle, Jun 22, 2005.
  1. Mr Sparkle
    Mr Sparkle
    Oct 17, 2003
    212
    Currently 2 years into using a Hitachi PJ-TX10 projector. Cannot fault it's performance or operation. This uses a WVGA (848 x 480) LCD panel.
    With the forthcoming advent of HD, I'm considering an upgrade to a WXGA (1280 x 720) machine and two years worth of technical improvements.
    I guess the budget is around £1K +/- £200
    No particular preference for LCD or DLP. Guess I need HDMI/DVI.
    What's the 'best' (I know everything is subjective) projector doing the rounds at the moment ?
    Any recommendations ?
    TIA
    Mr Sparkle
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    If you're pleased with the TX10, the TX100 will blow your socks off.
    But the Sanyo Z3 is comparable, has come down in price to match the TX, and has a longer warranty (as well as the dust removal thingy) hence I'd probably go for that...PJ :)
  3. sainthalo
    sainthalo
    Feb 24, 2005
    646
    19
    I'd say its really either the ae700 or the z3.
    The z3 has more pros than the ae700 or tx100 as mentioned.
  4. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Dunno, I still like the TX100 over the Z3, not really sure why. The other big one is the H30a - fantastic projector but no HD resolution.
  5. DEANO-B
    DEANO-B
    Oct 15, 2004
    516
    Leeds
    For less than a £1000 you can get the Z3, Hitatchi or the 700! (what a choice!!) I don't think you'll go far wrong with any of these hi def PJs. Myself personnaly have a 700 and cannot fault it. I've had it from when they first came out and have had no problems and have clocked up 2750 hours :eek: . If you do go for the 700 make sure you get the latest firmware 1.07!
    Good luck!
  6. sainthalo
    sainthalo
    Feb 24, 2005
    646
    19
    2750 hours! wow! im geussing there are lots of people enjoying it!
