blue_harvester
I have about £70 - £80 to spend on a DVD player to go with my new Toshiba 42PW33 rear projection tv and up until today I was going to purchase the Toshiba SD-340E (multi-region) dvd player as it got brilliant reviews in What Hi-Fi. However after reading a bunch of threads on here I think I'll not bother.
I'll just be using the player to play movie discs only (R1 and R2) and not DVD-R etc. Should I go for the SD-340 or what other budget player do you guys recommend?
