Best budget DVD-P?
Discussion in 'Blu-ray & DVD Players & Recorders' started by NinjaKi11a, Feb 19, 2005.
  1. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Intentionally, I haven't been keeping up with hifi and home cinema (oddly looking at the websites and even buying a simple magazine ends up costing me hundreds of pounds), however I am being asked to buy a DVD player for a relative. I'm looking for something cheap, multi-region, rgb capable and simple to use; prog scan would be a nice bonus but is by no means crucial.
    Thanks in advance.
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Pioneer DV575 ??
  3. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Thanks for the reply. :)
    I looking for cheaper than that though. I'm talking bargain basement here.
  4. superpixel
    superpixel
    How about...(all MR prices)
    Philips DVP520 (£50)
    Sony DVP-NS355 (£60)
    Toshiba SD240 (£50 - with prog scan)
    Pioneer DV370 (£60 - with prog scan)
    I can personally vouch for the Sony and Philips performing well and playing back everything they should (the Sony's remote, interface, build and sound is better - the remote can control TVs too).
  5. Mrhappy37
    Mrhappy37
    Mar 6, 2004
    452
    Kent
    +72
    I can vouch for the pioneer dv370. Its a blinding machine, both sound and picture. :smashin: £59.95 at richer sounds
  6. Mrhappy37
    Mrhappy37
    Mar 6, 2004
    452
    Kent
    +72
    By the way, if you buy from richer sounds stores you need to tell them you saw £59.95 on the web site.
  7. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Great stuff. Thanks very much for the help guys. Tosh 240 it is. :thumbsup:
  8. SNICK
    SNICK
    Feb 4, 2001
    793
    28
    UK
    +29
    Tesco Extra's have the Tosh 240e - i think for 49.95 - not sure if it's MR though :confused:
  9. stripe
    stripe
    Apr 7, 2004
    1,294
    Scotland
    +124
    If you are running it through RGB you won't need a Progressive Scan player, it only does PS through component.
