Best Blu-Ray player for apps and network streaming
Discussion in 'Blu-ray & DVD Players & Recorders' started by geojay, Feb 26, 2013.
  1. geojay
    geojay
    Nov 24, 2008
    58
    I'm looking to buy a Blu-Ray player but am also interested in being able to stream video from a NAS and the availability of on-demand TV / film apps.
    For the on-demand apps I get the impression that Samsung is my best bet currently (iPlayer / Netflix / Lovefilm) and for the future (4OD / Curzon). Is that a fair statement?
    For video streaming, I'd like to be able to use Ethernet to stream video in a variety of formats from a NAS (Netgear ReadyNAS Duo).
    A fast start up time would also be nice. I have no interest in 3D.
    Based on this, can anyone suggest a Blu-Ray player that I can get currently in the UK?
    Thanks in anticipation
  2. signs
    signs
    Nov 28, 2005
    21,490
    nr burton on trent
    +3,316
    What about a PS3 ? :)
  3. geojay
    geojay
    Nov 24, 2008
    58
    A PS3 would seem overkill, I'm looking to spend about the minimum required to meet my requirements. Anyone?
    Can anyone suggest where I might be able to compare the features of current players?
    Thanks!
  4. signs
    signs
    Nov 28, 2005
    21,490
    nr burton on trent
    +3,316
  5. JinDavid
    JinDavid
    Feb 27, 2013
    7
    How about a Blu-ray Player Software? As far as I know, Mac Blu-ray Player released by Macgo is a very strong-function player for both Mac and PC to play Blu-ray directly.:thumbsup: Also it is the first success in this field. There is no doubt about its high quality.:smashin:
  6. geojay
    geojay
    Nov 24, 2008
    58
    I've actually just got rid of a HTPC, I found it too complex for my requirements. It always started up update Windows, Java, Flash or its anti-virus software ten minutes into a film. I want something that is as simple as my DVD player that will handle the majority of on-demand and network streaming tasks. For anything it can't do I have a laptop and an hdmi cable as a last resort back up. I really do want simple and relatively cheap.
    Many thanks!
  7. JinDavid
    JinDavid
    Feb 27, 2013
    7
    What I mentioned above Macgo Mac blu-ray Player is capable of any kind of Blu-ray playing with easy enough operation I thought.At the same time, its quality isn't reduced because of this. As to the price, is also acceptable. Or get its free trail version first.
  8. p3eps
    p3eps
    Aug 12, 2008
    94
    +3
    I'm looking for something similar, so am looking forward to some sensible suggestions.
    I've just returned a Samsung BD-ES6000 to John Lewis as it played my MKV / AVI files with stuttering video - both off a USB memory stick and off my Synology NAS. The files played stutter free directly on the TV - so it wasn't the files.
    I swapped it for a Panasonic BDT220 today, but unknown to me the Panasonic unit won't play AVI or MKV over DLNA - only off USB... so is useless!
    Now I need to find something else that will play large MKV / AVI files over DLNA, and doesn't stutter. Perhaps the Samsung BD-ES6100... although I fear it may suffer from the same stuttering as the 6000?
  9. p3eps
    p3eps
    Aug 12, 2008
    94
    +3
    After reading a few other posts on similar topics, I think I might go with the LG BP620. All the players I've been looking at are around the £100-150 mark. The LG is the cheaper than the rest (£100). Some reviews say the menu system is slow at navigating through media files - but currently it may be the only option that does what I require?
  10. steve23094
    steve23094
    Sep 12, 2012
    23
    3
    What did you end up getting, and how is it?
    I'm looking for good streaming and media support too.
    I have a Panasonic BDT-500 but I'm about to return it for a refund because it's my second one that has blown up in exactly the same way. They can't be very reliable and I have lost faith in it.
