Best AV Receiver / Hifi + Speaker Combo around £550
Discussion in 'Hi-Fi Stereo Systems & Separates' started by MrSnooch, Sep 2, 2013.
  1. MrSnooch
    MrSnooch
    Sep 2, 2013
    5
    London
    Hi All,
    I am new to this.
    I am looking at purchasing my first good quality Audio equipment.
    I am looking at the Denon CEOL Piccolo and the Q acoustic concept 20 speakers as a package.
    Firstly, I want to know what people thought of this as an initial set-up?
    I test them out at a store and really like the quality.
    For me, Sound quality was of most importance.
    I also want a unit that can connect to the internet / iphone so i can stream music/ play from multiple sources etc.
    Now what my dilemma is, should i go for a 5.1 setup or stick with this 2.1 setup and maybe add a sub later...?
    Are there better bundles at the £500-£550 mark out there..?
    thanks
  2. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,655
    London
    +728
    Hi and welcome
    Seems to be a nice little setup and if you like what you hear, that's all that matters, but bare in mind that listening in a shop ( not demo room) and listening at home are 2 totally different things. Your room layout will be different and will have things in there that makes it a home a not a shop, like chairs, curtains, tables, shelf units, etc which attributes to how things sound.
    With regards to 5.1, do you A) need a hdmi connectivity B) do you want surround sound, C) do you have room for 5.1? If A and/or B is not required, then C is nothing to worry about as 2.1 will do and stick with the Piccolo. If A or B is required, then you need an AV.
    What other sources will be used and can the Piccolo handle that many sources?
    I have a 2.0 setup in my dining room and i have a SB Touch, TV, UDP and cassette Deck all hooked up to a stereo amp. No sub required or needed as what this delivers bass wise is more than ample.
    Music sounds great and Films just as good.
  3. MrSnooch
    MrSnooch
    Sep 2, 2013
    5
    London
    Thanks for the advice.
    I have gone with the Piccolo and Concept 20 speakers. Just waiting for delivery.
    I will let you know how they sound when i install it.
    On another note.
    Later down the line, if i was to add a Sub to my set-up, can you recommend any that would compliment this system.
    Not looking to spend more than £300
    thanks
    Neal
  4. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,655
    London
    +728
    BK Gemini II £215 or XLS200 which at £315 is just over budget
    BK Subwoofers
