Best AV Receiver for £900
Discussion in 'AV Receivers & Amplifiers' started by Shahel, Nov 5, 2004.
  1. Shahel
    Shahel
    as title states dont mind spending £50-100 more
  2. colinhare
    colinhare
  3. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,477
    Cornwall
    +120
    i'd demo rotel 1056, denon 3805 & arcam avr300. Question is what are you going to use it for 50-50 music/movies? do you want any particular features auto setup, 7.1, video conversion?
  4. richardS
    richardS
    Sep 14, 2004
    74
    for my money it has to be the Denon 3805
    I looked at all the ones listed above and it has no peers when it comes to Stereo, let alone AV.
  5. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,477
    Cornwall
    +120
    Probably right about "for the money" as the denon has come down way below 1000. But while i agree with the av there is no way that it matches in stereo.
  6. Shahel
    Shahel
    mainly for home cinema 7.1 would be nice and has to have atleast 2-3 component inputs
  7. NC11
    NC11
    Sep 19, 2004
    465
    London
    +7
    try the pioneer AX5Ai.
  8. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    I run a Denon 3803 which I'm very happy with, if the 3805 performs as well then it would definitely get a place on the audition list. The AVR300 is certainly more musical though, both are worthy of a good listening to.
  9. Shahel
    Shahel
    it was one that i was looking at but from reviews i gattered it only had 2 component inputs?
  10. inzaman
    inzaman
    Dec 16, 2002
    7,972
    Derby
    +1,043
    Would echo the comments above about the AX5i and the Rotel.
    I have a Rotel 1055 (the predecessor to the 1056) which i have owned for almost 2 years now and i dont even have the bug to upgrade, i like it that much. Not only does it have an excellent processor but the amplification is also first class, as you would expect from Rotel.
  11. AndoverRed
    AndoverRed
    Sep 24, 2004
    252
    Andover
    +5
    Shahel,
    I would look to audition the following: -
    Denon 3805
    Arcam AVR300
    Yamaha RX-V2400 or RX-V2500
    Pioneer AX5i
    I auditioned the RX-V2400 against the Denon 3805, and for movies, the Yamaha was king. The Denon was impressive in stereo though. I will try the Arcam this weekend.
    The new RX-V2500 looks good from an early review, and if home cinema is your preference, this should be your main target. AVLAND sell it for a grand.
    Then again, you could buy an RX-V2400 for less than £700 and spend the rest of your budget on a subwoofer, power amp, or christmas presents :laugh: , for example.
    Regards,
    Mark
  12. Shahel
    Shahel
    one other thing the component connections have to be good for HDTV
  13. richardS
    richardS
    Sep 14, 2004
    74
    I've actually given mine that extra boost - by bi-amping the front speakers, which I think brings the gap closer between the 3805 and the Arcam....I also think that at this level only your ears can really make the choice - and what your priority is (Stereo/AV - ease of configuration etc).
  14. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I would try these:
    Denon 3805-movies, some music
    Rotel 1056- movies, music
    Arcam 250/300 - movies, music
    Yamaha 2500 - movies
    Maratnz 8500 - movies, music
  15. bobbypunk
    bobbypunk
    I also agree about the arcam AVR250/300
    The only thing that really pulls the gap back towards it from the 3805 is the ability to bi-amp the front two in 5.1 on the Arcam aswell!
    The important difference between the Arcam and Denon is the power. Arcam rate the AVR250 at 75Watts RMS per channel and this is a real figure for all channels running together, whereas the Denon's claimed 120 Watts reduces drastically when all 7 channels are running!
  16. Radiohead
    Radiohead
    Dec 24, 2001
    4,396
    Amazingstoke
    +432
    Why exclude music from the Yamaha?
  17. V5-APS
    V5-APS
    May 7, 2001
    681
    London
    +15
    The AX5i can be had for £750 now.....that's not bad going !!
  18. Shahel
    Shahel
    where have you seen it for £750 m8?
  19. Alex-1701
    Alex-1701
    I have had the Denon 3805 for about 6 months and think it is fabulous. Movies come over really well - brilliant quality, but I would agree with someone else who suggested spending time an effort getting the speakers right.
    I also like having the master volume displayed on the screen, so that I don't have to squint at the pannel on the front of the amp.
    The remote control is extra special too. Lots of buttons that can operate lots of other devices, and it only lights up when you pick it up. Unlike some people who report problems mine has performed perfectly well (although it is a bit thirsty on power).
  20. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    The MArantz SR8500 should be a great buy, it is the one I'm hoping to bag next yr, here's hoping :D
  21. V5-APS
    V5-APS
    May 7, 2001
    681
    London
    +15
    Sevenoaks are selling the AX5i's off for £750 !!
