Best AV amp setup for SACD and 5.1 DVDs?
Discussion in 'AV Receivers & Amplifiers' started by AgeOwns, Nov 28, 2004.
  1. AgeOwns
    AgeOwns
    Jul 28, 2004
    71
    9
    Macclesfield
    I am about to purchase a Pioneer 575A DVD player for my Denon 2805.
    I understand i need to connect 6 analogue rca leads from the dvd to the amp to hear the SACD and DVD-A.
    HOWEVER, would i send the DTS and 5.1 sound from normal DVDs through the analogue leads as suggested by the bloke in SevenOaks, Manchester?
    Wouldn't my Denon 2805 amp have a better decoder in it for DVD movies? Shouldn't i stick to digital coax?
    Plus (if you own a 575A) can you set it to remember that SACD is to play through the analogue and DVD movies through the digital out?
    Cheers, any replies very much appreciated. :smashin:
  2. recruit
    recruit
    AgeOwns you want to connect the 6 RCA connectors for SACD / DVD-A and for the DD / DTS you want to connect you're Digital lead and let the amp decode the Signal, there should be a Direct mode for the Analogue inputs availible on the amp and then you just switch between the 2.
    John
  3. AgeOwns
    AgeOwns
    Jul 28, 2004
    71
    9
    Macclesfield
    Thought as much. Many thanks, I didn't 100% believe the guy at SevenOaks.
    Cheers :)
