Best av amp £1000?
Discussion in 'AV Receivers & Amplifiers' started by edgeman, Aug 4, 2013.
  1. edgeman
    edgeman
    Sep 22, 2005
    20
    Best AV amp for £1000, I'm not interested in any of the 4K pass through or upscaling or for any of the other multiple analogue connections, wireless streaming etc I don't need that stuff already have xbmc, squeezebox and NAS music and video alreay accesible from my devices.
    What I want is the best sound quality for a straight 5:1 (maybe 7:1 in the future), only thing it needs to support is 3d pass thru. Have a Denon AVR2310 currently with B and W M1's and PV1.
    I see sevenoaks have a good price on last years pioneer range lx56, 76 and 86 all at good discounts - as I mentioned above though I don't need/want half the features on them just the best sounding amp.
    Will the lx76 and lx86 be overkill for my M1 setup?
    I was thinking of maybe adding 2 B & W ceiling speakers to go 7:1, what are folks thoughts worth it or 5:1 good enough its a 5m x 4m room. Any recommendations for ceiling speakers to match the m-1s?
  2. MTech535
    MTech535
    Aug 27, 2012
    445
    +32
    Anthem MRX300.
    A bit over budget, but....
  3. edgeman
    edgeman
    Sep 22, 2005
    20
    Thanks must admit I hadn't heard of them before other than their hifi gear but a bit of research does seem to suggest they are rather good - though ugly!
    Anyone got any other thoughts MXR300 vs LX76 is there any contest around the £1K mark.
    Has anyone has issues using the MXR300 with XBMC or via a PC attached i.e. the PC seeing the device as a Video card etc.
  4. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    I'd add a plus 1 for the Anthem
    Alternatively we have the Yamaha RX-A2020 in titanium available for £999 in our AVforums offer thread.
    We also have a Anthem MRX500 offer as well
  5. shirish
    shirish
    Aug 6, 2013
    Where can I find the offer you have mentioned about Anthem MRX500 ?
  6. kalimon
    kalimon
    May 29, 2007
    1,745
    Manchester
    +131
    I've got a pioneer lx85 which is great but like you, I only run a 5.1 system. My speakers aren't bi-wire able so I don't use the majority of my outputs. I've heard good things about the anthem and I'd have a good look at that as its room correction is supposed to be among the best. I didn't get an anthem because my speakers are 4 ohm and it mentions in their literature that it isn't suitable for 4 ohm speakers although it would probably have been fine.
  7. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
  8. the_dude2
    the_dude2
    Oct 2, 2008
    2,185
    117
    Romford, Essex
    +1,025
    Oh, where does it say that about not running 4 ohm speakers? My manual was in French!
    I never checked before i got my KK's if it could or not. Thankfully at the volumes i normally run at it seems fine but occasionally i can detect a slight hardness to the sound when im giving it a quick blast just for the fun of it.
    To the OP, Anthems are superb sounding receivers.
  9. kalimon
    kalimon
    May 29, 2007
    1,745
    Manchester
    +131
    I recall reading it somewhere when I was looking at anthem amps. I use dynaudio speakers that are 4 ohm and it was a consideration when I bought my last amp. Wouldn't be the first time I've been wrong though 😞
