Best App for creating or using a blog
emptage
I will be spending a lot of time travelling over the next few years, for periods of up to 3 months at a time and want to create a travel blog. I will have my iPad mini with me and wonder what the best approach is. Should I use one of the special apps to create a blog and if so which one. Or should I should I use a PC blog which can be updated on an iPad, again any recommendations.
Derr1ck
Hi emptage,
I would strongly recommend using Wordpress, you can get a Wordpress blog setup for next to nothing. This way you can edit & update your blog from any device as well as your iPad. I'm a web designer and use Wordpress alot, let me know if you need any further help/guidance in getting things started.
emptage
Many thanks for the responses, I was hoping that would be the answer. I just wasn't sure I could operate a Wordpress account with an ipad. Can I ask, if you in the U.K. Which host you use and hitch you would recommend
Tim
