Best antivirus s/w?
Discussion in 'Desktop & Laptop Computers Forum' started by nathan_silly, Jul 13, 2003.
  1. nathan_silly
    nathan_silly
    I had to switch over from PC-Cillin 2003 to Norton Antivirus 2003 Pro, my PC seems alot slower now..
    Which antivirus s/w checks HTTP & POP3 incoming emails, has regular updates, and doesn't hog the system?
  2. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    I run norton 2001 on a 900hz machine. Seen and played with others like Mccaffe/PC-Cillin on other poeples machines.
    Think you should stick with norton
  3. Kramer
    Kramer
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +294
    I use pc-cillian2003 and do not suffer any slow down that's noticable. Updates seem to be available every other day and I've never had a virus scare since using it. I've tried norton and mccaffe in the past and didn't seem to get on with them.
    I used avg antivirus for a year or so which is free to download here:-
    http://www.grisoft.com/us/us_dwnl_free.php
    I thought it was gr8 and only changed because I built a new system which had pc-cillian as part of the software that came with my mobo.
  5. CENSORED
    CENSORED
    Norton.
  6. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
  7. Kalef
    Kalef
    Sep 24, 2002
    Devon
    +3
    A very good and free AntiVirus proggie with regular (automatic) signature updates is Avast! Very light on system resources and has saved me a couple of times from infected Emails.
    I recommend giving this a go before paying out for a virus checker.
  8. gunrock
    gunrock
    Apr 3, 2003
    132
    The Burbs, London, UK
    Nathan,
    Why the swap from PC-Cillin? I've been using PC-Cillin since version PC-Cillin 98 through to 2000 and now 2003. It's one of the best anti-virus software's I've ever used (I've extensive experience with Norton via work). Very good if you keep up-to-date with your virus pattern files.
    PC-Cillin can check for deviant ActiveX controls and Java applets and monitor POP3 mail for viruses without taking too much CPU, on my AMD K6III-450mhz system (which is currently my main system).
    I think you may have Norton doing real-time scans of every file that is loaded and executed, this can slow your machine down considerably. It would be better to turn off real time scanning and schedule a daily (or nightly scan) on executables/partition tables and a fuller weekly scan on all files.
    HTH
    Gunrock
  9. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
  10. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Another vote for Sophos
    Paul
  11. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Panda Antivirus Titanium is a superb little program that has daily updates on offer (with tiny downloads) and is very resource efficient. Check it out ;)
