Best and Biggest LCD/Plasma for under £1000!
Discussion in 'LCD & LED LCD TVs' started by Hampsterhunter, Jan 3, 2005.
  1. Hampsterhunter
    Hampsterhunter
    I don't have any idea about LCD TVs but I'm looking for a minimum 27" screen with a tuner in built.
    I'd be grateful for anyones help with this as my budget is tight and I can't afford to get this wrong.
    Viewing distance from the screen will be about 6-8 feet.
    :clap: :thumbsup:
  2. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,411
    71
    Southsea
    +70
    the Vision PM4230 42in plasma can be had for about £1000 if you look around, although I doubt its much good considering its price:size ratio.
    Hitachi 28LD5200 28in LCD goes for just under £1000
    Toshiba 30WL46 30in LCD can be had for just over £900 if you look around
    Toshiba 27WL46 27in LCD about £750-£800
    Sanyo CE27LC3B 27in LCD at a bit over £800
    Thomson 27 LCDB 03B 27in LCD around £950
    I personally would for the 27" Toshiba, but wait for others to chip in.
  3. abay710
    abay710
    32 Inch Goodmans from Comet @999
    Just got one of these and am really pleased with it
  4. Hampsterhunter
    Hampsterhunter
    Thanks for your views.
    I'm suprised there aren't more out there :cool:
  5. NickXX
    NickXX
    Bought a 27WL46 last week. Very pleased with it so far - using it with Digibox and PC DVI-in.
  6. Taz69
    Taz69
    Apr 15, 2002
    2,324
    Bristol
    +54
    If you are intending on going the Hi-Def route when Sky launch it next year, you will need to look for a model with DVI in (HDCP over DVI is the correct term I think) The new Tosh WL48 models have this I think, the bargain was the Tevion 27" LCD TV, £599 from Aldi, not sure if you have any near you, you may be lucky if you can track one down, I have 1 on order, can't wait, there is a thread on it in the main forum.
    Hope this helps, I know your on a budget but you dont want to buy now and find out it wont do what you want it to do come next year, although it may be 2007 before Sky get there act together.
    Taz69
  7. cornelis
    cornelis
    I had much the same criteria. Just bought a Hitachi 28LD5200 from PRC for £954 (though I notice the price has just gone up a bit) and so far I'm very pleased with it.
  8. thfccambs
    thfccambs
    Jul 17, 2002
    18,769
    White Hart Lane
    +4,812
    What about the sharp GA4 26" can be had for £999 @ robert whytes.
  9. deadred
    deadred
    Nov 18, 2004
    2,523
    71
    Cumbria
    +89
    They are out of stock mate, i tried them, you can get the GA3 model though
  10. thfccambs
    thfccambs
    Jul 17, 2002
    18,769
    White Hart Lane
    +4,812
    John Lewis have them in stock so do crampton and moore,im just waiting for JL to get back to me about a price match.
