best all in one system for less than £900?
Discussion in 'Home Cinema Buying & Building' started by Nippy_Kangaroo, Jun 25, 2004.
  1. Nippy_Kangaroo
    Nippy_Kangaroo
    I am currently looking around for a all in one system which includes speakers (wireless if possible), AV reciever/amp, progressive scan dvd player and maybe freeview box if possible (can buy freeview box on its own if i have to) with component inputs so i can play xbox through component input progressive scan but i have a smallish front room so i dont need powerful speakers.
    I've already seen a plasma that i like the look of and now I just need to choose a home cinema package (really confused as to which is best for my budget)
    I've got around £800-£900 to spend
    thanx in advance :smashin:
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,092
    notts.
    +64
    The marantz hollywood in a box would be ideal its got everything that youve listed should be £1000 but empire direct are doing it for £694 with £10 delivery.check the marantz website for pictures of the receiver and dvd player both are slime line units very nice looking.
    It has had good reveiws as well for what its worth.
    Cheers Gonzo. :)
    ps hifi bitz have a good image of the system.
  3. Nippy_Kangaroo
    Nippy_Kangaroo
    thx for the info, I'll check it out now :)
    cheers :smashin:
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Peter tyson should have some good deals on this and more reliable than empire.
  5. Nippy_Kangaroo
    Nippy_Kangaroo
    Just had a look and i cant see that particular model on their website but they have lots of other marantz systems for sale but how do i know which is the best one for me?
    Does anyone know any good sites where i can find reviews for marantz holywood in a box home cinema system?
  6. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,092
    notts.
    +64
    Hi Nippy
    Did you look on the hifibitz web site there is a very good image and information about the hollywood system click on the more info image and it will take you straight to the marantz site on to the page hollywood system.
    Cheers Gonzo. :)
  7. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,092
    notts.
    +64
    Ive just checked my dvd review mag issue 65 where theres a 2 page spread on the hollywood system they said it is fantastic and given it 5 stars and thats at £950.
    Hope this helps.
    Gonzo.
  8. Nippy_Kangaroo
    Nippy_Kangaroo
    yep, it looks really cool packed with nice features... the only thing that puts me off a little is that its a dvd slot instead of cd tray by the looks of it, I've heard that they tend to break easily compared to cd trays?
    Also, i cant find any info on what inputs/outputs its got... do they think it will have component input and output?
  9. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    i'll add my 2 cents and say the marantz hollywood is excellent. pm your email addy and i'll send you some very high res images of the machine :smashin:
    its a progressive scan player so it must have component output :thumbsup:
    ps dont worry about pm i'll upload the pics to web space for ya in a tick
    right the res of these images are 2334 x 898 so 56k er's beware :)
    right amp and player
    http://img78.photobucket.com/albums/v298/BauerCTU/sr2400dv2400lrg.jpg
    Mordant Short Speakers
    http://img78.photobucket.com/albums/v298/BauerCTU/ss2400lrg.jpg
    enjoy
  10. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,092
    notts.
    +64
    Hi Nippy
    Excuse my ignorance but does the xbox have component out or did you need a receiver with up conversion if the later you would be hard pushed with your budget to get a full system for £1000,If the xbox does have component out you will be able to connect this to most plasma hardware anyway.
    Cheers Gonzo. :)
    I shouldnt worry too much about the dvd tray marantz build quality is usually very good,only thing that would worry me is young rugrats using it as a money box. :D
  11. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    to have component out from an xbox i THINK u need to have the box modded. this is definitly the case if u want a PAL Xbox to output High Definition Signals (seriosuly Reccomend Doing if hooking up to a plasma or Projector)
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Also consider Paany SC-HT37R DVD-recoder and amp in silver with nice speakers and a big SOUND!
  13. fulllupo
    fulllupo
    Jan 25, 2004
    271
    Cambridge
    +44
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Should have the 90 set up soon so will let you know specs look good but panny 25/37 are very good!
  15. Nippy_Kangaroo
    Nippy_Kangaroo
    Thats the only trouble, there are too many nice looking aio's about and hardly any info/reviews about them :suicide:
    so far i like the look of these two...
    marantz hollywood http://avland.co.uk/marantz/hiab/hollywood-in-a-box.htm
    Denon 770SD home cinema system http://www.unbeatable.co.uk/CatalogueItem_19591.html
    both look very nice but at the moment the denon system looks more appealing to me as its got 2 component inputs so i could connect panny6 plasma upto it and run my modded xbox through component input on denon AV reciever.. saves me a bit of money because i wouldnt need to buy a component video card for TV, I'd connect AV reciever through vga port.... but...but... i cant decide :confused:
    are denon and marantz good makes or am i better off sticking to well known manufacturers such as sony, panasonic and samsung?
  16. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    both denon and marantz are very very good makes IMO ! both systems will suit you! pm me i have A Reviews For both Systems that ive scanned from a mag for another user. i zip them together if you want
  17. ngeorge
    ngeorge
    Jul 13, 2004
    35
  18. TJChelsea
    TJChelsea
  19. Nippy_Kangaroo
    Nippy_Kangaroo
    Yep, I like the look of this as it supports divx/mpeg files but I dont think it has any component inputs which i really need... pity :(
  20. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    ye that only has one component output ! IIRC the denon has 2 component inputs
    edit:yes the amp does have two component inputs and what the denon has over "hollywood" and Jamo is 6.1 both DTS ES and DD EX which more and more DVD's are Adopting these Days :smashin: when u go 6.1 you never want to go back IMO
  21. Nippy_Kangaroo
    Nippy_Kangaroo
    Yep that pretty much does it for me, I'm going to buy the denon 770 aio as it's got 2 component inputs and is 6.1 if u buy extra centre speaker :smashin:
    only think I'm not keen on is speaker placement, I have 6.1 sound for pc and i have wires running everywhere, I usually trip up over them once a week :thumbsdow :rolleyes:
  22. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    if i were you as well id go to an online cable store and buy decent Speaker wires. i did this and made a world of difference to me. no point in spoiling a gr8 system with bad interconnects. most of the time the manufactuers supply of cables is some what less than to be desired :lesson: cant u just get extra lengths of cables then tack them to skirting boards, bottom of wall etc ??
  23. Nippy_Kangaroo
    Nippy_Kangaroo
    not with my surround sound for pc coz the cables are built into system and arent very long so i have to run them straight through middle of room :(
    But I will definitely do what you suggested when i get denon aio for living room. :smashin:
  24. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    ye i was getting at the living room. nothing worse than cables all over the place :nono: glad to be of help and hope you enjoy your system
