Best acoustically transparent Velour / Velvet black out cloth
Discussion in 'Home Cinema Building DIY' started by Tyler Durden, Sep 11, 2012.
  1. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,609
    Shrewsbury, UK
    +327
    I am looking to cover an entire wall (except the screen) with a black velour like the Devore from Whaleys. But as the speakers are part of the wall then the cloth will need to be acoustically transparent.
    Does anyone have any ideas for this?
    Can I just use the Devore?
    Thanks in advance for any help.
  2. mbmapit
    mbmapit
    Feb 15, 2005
    1,885
    Stansted
    +428
    You'll be fine using Devore buddy, just do a recalibration of your speakers after. If memory serves me right I had to up mine by 1.5db to compensate the material. Hope this helps.
