Question Best 75 inch TV for around £1k
Discussion in 'What Is The Best TV For You?' started by craig7, Apr 15, 2019 at 2:07 PM.
  1. craig7
    craig7
    Dec 6, 2010
    41
    Folks what's the best 75inch TV for sport around 1k mark
  2. Trollslayer
    Trollslayer
    Feb 11, 2007
    25,267
    Poole
    +10,316
    I would be extremely surprised if there is one at all.
  3. Dodgexander
    Dodgexander
    May 29, 2007
    14,373
    +4,228
    There are only 75" TVs from LG and Hisense near £1000 and they are both only use 60hz panels so won't be fantastic with sport.
    If you don't have high standards or you don't use the motion settings with a TVs settings though you may get along with them fine.
    Hisense have the A series.
    And LG their UK6xxx series is available at 75"
    Between the both the LG may have a marginally better response time, with better smart TV too but the Hisense, if viewing direct in front will be the better TV in terms of screen uniformity, blacks and contrast.
    They are both in the guide here: My best value TVs, 2018-2019 Edition
  4. craig7
    craig7
    Dec 6, 2010
    41
    What abut a 65inch?
  5. Dodgexander
    Dodgexander
    May 29, 2007
    14,373
    +4,228
    Much better options at 65" in the Hisense U7A and Samsung NU8000 although you may find the latter hard to find now in mainstream stores.
    If you don't mind having a TV with an IPS panel there is also the LG SK8500.
    Which panel type should I choose for my TV?
