NewHouseTV
Hello All
Have read a lot of forum posts but still struggling to find what I looking for. Just moved house so looking for a bigger TV.
Don't want to spend OLED budget so am looking for something that is £600 - £800 (TV expectations are inline with this).
Use: General purpose TV
- FreeSat / TV / Netflix / iPlayer
- Movies (Not blueray)
- No gaming really (odd game of Mario Kart once in a while)
- Use the Menu / OS of the TV quite a bit so don't want anything too slow
- Must be 65"
Lounge - The viewing angles will be fairly narrow and am toying with mounting on the wall / Buying a new much larger stand.
Fairly bright mulit-purpose room
Thoughts:
Panel
Sounds like a VA panel would be better for this location?? Annoying that LG don't seem to make them.
Make / Menu
Am a little bias to LG as always have been good for me in the past and I like the menu features. Find my current TV can be a bit laggy so reading reviews of Sony / Samsung menu's / OS is preventing me from leaning towards them. Seems like if I want a modern OS/Menu at this price I have to have a IPS Panel.
Sound
Will be buying a sound bar at a later date.
Summary
Happy to be corrected on any of the above, Just need a good allrounder for under £800. Don't really want to pay 800 for something almost the same features as the £650. Is 50hz vs 100hz a deal breaker, should I be focusing on VA rather then IPS,
a few I have looked at but open to ideas...
LG 65UM7660PLA - £649 -Seems pretty cheap, build quality worries me. Panel Frequency is only 50Hz, Is this a problem?
LG 65SM8600PLA - £800 Has True motion and 100 Hz, very similar to above but quite a lot more expensive.
Sony BRAVIA KD65XG8505BU - £800 - Good reviews for the picture but has lots of bad reviews for the OS/Menu
Thanks in Advance for any help
- Must be 65"
Thoughts:
Panel
Make / Menu
Sound
Summary
LG 65UM7660PLA
Delivering an immersive picture, the LG 65UM7660PLA draws you into the onscreen action. 4K Active HDR for optimal picture qualityEvery scene is optimised with 4K Active HDR.
www.richersounds.com
LG 65SM8600PLA
With AI at the heart of its picture, sound and smart tech, the LG 65SM8600PLA offers tomorrow’s tech, today. Nano Cell technology – everyone gets the best seat in the houseUsing uniformly sized display particles, this LG 65 inch TV gives enhanced colour accuracy and the ability to produce wider...
