Best 6 speaker set for £200 :-(
Discussion in 'Home Cinema Speakers' started by fozziebear39, Oct 14, 2003.
  1. fozziebear39
    fozziebear39
    Jan 3, 2003
    993
    Newton-le-Willows
    +43
    I know the budget is a bit small but at least the room is small as well :)
    The room is 12' x 8' and I would like the speakers to be relatively small as well (apart from sub)
    Is RicherSounds the way to go or do I need to save more!
  2. SanPedro
    SanPedro
    Jan 11, 2001
    4,503
    +504
    Fozzie
    Even going to richer sounds I would try and save a bit more. Something like the Mordaunt Short premier system at £299 from RS would fit the bill. It's from a respected manufacturer, small and only £100 more than your original budget. But if you can afford to save more, then I would do. You could always consider 2nd hand. There have been some terrific bargains in the classifieds here. You could easily get a decent set for £200.
    Chris
