Best 6.1 amp i can get for £550 ?
Discussion in 'AV Receivers & Amplifiers' started by fishyben, Feb 10, 2002.
  1. fishyben
    fishyben
    As the header said "Best 6.1 amp i can get for £550 ? "
    Thanks, Ben
  2. oreoboy13
    oreoboy13
    you can get a Denon 3802 for £620, its probably worth the wait it takes to save up.
  3. WSC
    WSC
    Nov 1, 2001
    60
    Try the Marantz 7200 - can be got for less than £500. I've got the 5200 for £350 (has been on offer for as little as £305 ) which has 6.1 and I like loads.
    Listen to anything recommended before buying - your likes won't necessarily be matched by others.
    Good luck
  4. Craig_Nike
    Craig_Nike
    I know everybopdy will roll their eyes as they see this - but I have to put in a vote for the QS Sony 1070.
    It is a great mahcine and is considerably cheaper than Denon 3802. (apperently 299 ast RS)
    Guess it just depenmds on your budget. Spend 299 and spend the rest on moves !
    The only thing the 1070 doesn't have is DPLII - but a few people are not that impressed with DPLII anyway. If you're watching mostly DVD movies thans DPLII is irreveant.
  5. fishyben
    fishyben
    Thanks guys,
    I went out and auditioned a few today, denon 3802 and Marantz 7200 to name 2 of them.
    at the moment i have a sony strdb940 and to be honest the 1070 is much the same but with 6.1.
    Anyway i'v purchesed the Marantz 7200 for £499 (free p&p) for www.avland.co.uk i'll let you know how i get on with it when it turns up.
