Hi All,
Looking through a number of TV options, my budget is 1.2k MAX but ideally lower. Whilst a big gamer, I'm already sorted on that front so the most important thing for me is top notch viewing of standard TV, netflix, sports etc. I'd really like a tv that will make 4k movies and 4k tv series really pop, along with sky sports ultra.
I've looked through a number of different sets, the entry level OLED LG, couple of Sonys, QLEDs etc.
The room is pretty well lit during the day, gets dark in the evenings, its not directly next to any windows but those are around if that affects reflections etc. Based on the above, what would you recommend?
Can give more detail if needed, to the untrained.. there is a lot of tvs, which seem to look the same but evidently are not at all, based on panel, tech, sound, etc and I need help to figure out the logical best buy. I'm in the UK if that makes a difference.
