Question Best 55" 4UK UHD HDR TV for <£800?
Discussion in 'What Is The Best TV For You?' started by gam3r, Jul 20, 2018.
  1. gam3r
    gam3r
    Mar 22, 2006
    261
    London
    +4
    Hi All,
    I am a bit out of touch with the latest tech.
    What would you recommend for a £800 budget (can stretch a little more ~100 if needed)?
    Min requirement is I want something which is 55".
    Many thanks for your help.
  2. zeppelino
    zeppelino
    Jan 24, 2018
    3,931
    134
    UK
    +1,205
    If still available Samsung MU 7/8/9000. But they’re thin on the ground so you’ll have to do some searching.
  3. BobTheViewer
    BobTheViewer
    Oct 16, 2008
    160
    28
    +41
    Might find some Panasonic TX-58EX750B about.
  4. Dodgexander
    Dodgexander
    May 29, 2007
    15,207
    +4,407
    ElectriQ oled recently recommended here on avf. Other suggestions above are good too.
    I wouldn't consider a 2018 model apart from the Hisense U7A but that's only at the bottom of your budget.
  5. gam3r
    gam3r
    Mar 22, 2006
    261
    London
    +4
    Thanks guys, will check those models out. Thinking of potentially stretching to around £1000 now.
  6. zeppelino
    zeppelino
    Jan 24, 2018
    3,931
    134
    UK
    +1,205
    Sony XE9005 is £999, but again thin on the ground.
    Noticed Samsung NU8000 is same price, down c£500 since launch - though will come down further still.
