Question Best 50" for Sky Q & PS4 Pro
Discussion in 'What Is The Best TV For You?' started by gaz847, Aug 15, 2018.
  1. gaz847
    gaz847
    Dec 24, 2006
    411
    Dorset
    +7
    Hi, I have just moved house and need to find a tv for my lads bedroom. It will most likely be wall mounted and no bigger than 50". It will be feed with Sky Q and a PS4 Pro. More than happy to consider last years models, or wait until Nov for price drops, or buy second hand. Thanks in advance.
  2. Angelo M
    Angelo M
    Jan 25, 2015
    543
    Terlizzi
    +76
  3. Dodgexander
    Dodgexander
    May 29, 2007
    13,889
    +4,037
    If you buy at black friday its likely a new model like the XF9005 will be cheaper.
