Best 5.1 Speaker System In The World!!!
Discussion in 'Home Cinema Speakers' started by avf20145, Feb 24, 2014.
Thread Status:
Not open for further replies.
  1. avf20145
    avf20145
    Feb 22, 2014
    1. What do you think the best 5.1 speaker system in the world is to go with a 60inch plasma?
  2. kbfern
    kbfern
    Aug 17, 2002
    17,929
    Wolverhampton
    +6,093
    Have you upped your budget then, just trolling or what?
  3. avf20145
    avf20145
    Feb 22, 2014
    Depends how much they are... can't be overkill for the size of the screen.
  4. kbfern
    kbfern
    Aug 17, 2002
    17,929
    Wolverhampton
    +6,093
    You seem to put together pretty pointless questions really.
  5. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    Have a couple of million to spend? and I am sure we can spec something for you that will be the best in the world. 60" is hardly a big screen either.
  6. avf20145
    avf20145
    Feb 22, 2014
    Jamo? M&K? KK? XZT?
  7. kbfern
    kbfern
    Aug 17, 2002
    17,929
    Wolverhampton
    +6,093
    Not even close
  8. avf20145
    avf20145
    Feb 22, 2014
    go on.....
  9. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
  10. avf20145
    avf20145
    Feb 22, 2014
    What would be a better looking alternative to M&K and KK?
  11. twoeyedbob
    twoeyedbob
    Sep 6, 2011
    879
    ayrshire
    +318
    Mine..cost me 1.3 million....i'll gie you them for 2k
  12. lokyc
    lokyc
    Aug 28, 2013
    2,176
    83
    +429
    The best speakers in the world need to be matched with the best amps/processors. They'll sound ok with lower level amps, but just wouldn't be worth the extra money.
    It also depends on system integration, source material and listening preferences. Then of course there is the room size, and accoustics.
    When the Bristol show, ne of he things that impressed me about the massive, super high range speakers like the Dynaudio, is that it doesn't overwhelm. It sounds like a small speaker in an intiate room. So good speaker are just really good in that way.
    If money and space is no object, you could see take a leaf from studios. Abbey Road for example use an array of B&W 800Ds. What Hifi as good as sai they are the best speakers money can buy.
    Award winning Hollywood studios use the KK desigbed M&K speaker packages, and he is designing some radical pro level speakers for studios.
    The question is actually not that easy to answer as one would think. I can understand if peopel think ou are trolling. But its a good exerie. The wealth of knowledge here is amazing, and it would be interesting to know what's on ppl's wish list.
    Problem is a lot of the high end hifi speakers are designed and heard as stereo setups. Multichannel speakrs are quite another thing. 5 800Ds wouldn't necessarily be as good as a stereo pair.
    If I have the money, I would fly across the pond and ask KK to make me one set, install and tune for me.
    Or I can buy Russell a beer and pick his brain.
  13. spyder viewer
    spyder viewer
    Dec 18, 2007
    5,846
    2
    Kent, UK
    +1,285
    Why have you started a new thread when your other one appeared to be developing nicely? Why don't you continue with that one instead of asking the same questions here? I'll close this one for you to save effort.
Thread Status:
