mrhodes
Hi everyone,
I'm looking for suggestions for the best 4k TV at a price point of £1000 (can raise to £1100 depending on the quality of the TV).
Things I'm looking for:
- Low Input lag as I will be primarily using it as a PC monitor.
- 4:4:4 chroma.
- 10 bit panel.
- Direct LED - Can make an exception for Edge Lit if the TV has great reviews for it.
Thing I'm not looking for:
- OLED is beyond my price range and is prone to screen burn.
- Sizes below 40" or beyond 60".
LG 55SJ950V - 15ms Input Lag at 4k@60hz 4:4:4
LG 55 inch 4K Ultra HD HDR Smart LED TV Freeview Play
I was considering a Samsung Q7F TV, but it is an edge lit tv where the light goes from the bottom, as opposed to around the entire TV.
If you need more information, please let me know and thank you in advance!
Matt
- 4:4:4 chroma.
- 10 bit panel.
Matt
