RadioactiveCheese
Evening all,
I've spent a long time scouring through various forum posts and I can't make a decision.
I am looking at getting a new TV - current is 48" Seiko? got it super cheap many years ago to fill a space and now finally have a bit of money (and new house/bigger space) so what to upgrade. Might be worth noting our current TV is 'dumb' so this will be our first 'smart' TV.
Main use: BBC iplayer, Netflix, Disney+, Prime, Youtube, a tiny bit of Freeview. We have a firestick but also looking at a Chromecast with Google TV - unless this is pointless with either of the options below. Gaming wise I will only be using the Switch. Maybe BT sport if it's accessible.
Location - Against a large white wall in our living room with windows opposite - windows have blinds but we get a lot of sunlight in throughout the day (even with the blinds closed) and our current TV just cannot handle the light/glare and reflections - almost impossible to see nigh scenes etc.
The soft is up against these windows and so viewing will be straight ahead to the TV.
Budget: Probably around £650ish
Which of these would you pick?
Refurbished Hisense 55U8QFTUK 55" (£599.49) I appreciate this is refurbished - is that a major issue?
Hisense QLED 55U8GQTUK 55" (£634 inc £40 off) I have a £40 off code for this.
Hisense 55U7QFTUK 55" (£459 inc £40 off) I have a £40 off code for this.
Philips 58PUS8536 58" (£609 inc £40 off) I have a £40 off code for this.
If anyone has any other alternatives I would be more than happy to consider them.
Many Thanks in Advance for your help
