Why don't you want 4K? Many new TVs are and you are cutting back your choice. You don't have to watch 4K on it.
First up it's easier for TV manufacturers to produce 4K TV's than 4K and HD TVs. So it actually means lower costs going over to 4K manufacturing.Then why bother with it?
And? I have watched a lot of 3D TV, TVs aren't designed specifically for you personally and you admit you did use the feature anyway. Are you saying if you saw a decent 4K TV 42" TV you deliberately wouldn't buy it? You don't have to watch 4K. If it comes to it it's still smaller pixels and will upscale HD.I bought a 3D plasma TV 7 years ago and have watched 1 3D broadcast of tennis on it and played about an hours worth of 3D gaming in that time.
And you still just watch broadcast TVYou can barely find enough channels broadcasting in decent bandwidth 1080p to fully justify an HD set let alone a 4K set![]()
And you ignore that eventually all 42" TVs will be 4K anyway. It makes no odds whether it looks better or not. See reasons above. My TV has speakers on it. I never use them. It would take a lot of effort going round trying to find a TV without speakers so I ignore the fact they are there and just buy the best TV I can. Why don't you buy the best 42" TV you can and if it has more pixels making up your 1080p TV broadcast just not worry about it?And all this ignores the elephant in the room: 4k is hardly going to look at it's most jaw dropping best on 42 inch set! Lipstick on a pig when all you want is a good bacon sarnie![]()
Second, if your competitors are producing 4K TVs and the market has moved onto them then so do you.
Third if the cost isn't great then you might as well produce 4K.
Fourth as TV screens get bigger and bigger then the resolution has to get better or the quality drops.
Fifth it's still another feature. Features sell.
Sixth there is more and more 4K output.
More here as to why you'd want it:
11 reasons why your next TV has to be an Ultra HD 4K TV | TechRadar
What will you do when 8K arrives?
Super Hi-Vision 8K TV standard approved by UN agency - BBC News
First 8K TV screen to be put on sale by Sharp in October - BBC News
I have a UHD disk player, connect my PC to my TV, have a PS4 Pro and watch 4K TV via Amazon Prime on my TV. I also have a 4K GoPro camera and you can watch 4K on youtube if you don't have Amazon or Netflix or Sky or cable or BT. I barely watch broadcast TV but if I do it's still upscaled.
4K is something that has constantly got bigger. You want to buy a TV now and in a few years realise it is obsolete? Or buy one that is as future proof as possible?
Fine. If you can show me a review from anywhere, anywhere, saying 4K TVs are a bad idea, you are better off with an old plasma, it's all marketing bs or anything vaguely similar, I'll be happy to concede the point. Otherwise it's all just your own opinion.You mistake me for someone who hasn't already considered all of these things (ok so i admit, some i've almost immediately dismissed as marketing bs) and yet i still come to my original conclusion
For starters, it requires more processing power to stretch the image, something TV chipsets don't do very well as they aren't very powerful due to cost savings/power/heat restrictions. Secondly the more you stretch an image the more processing that's required at all, processing a smaller image to a larger resolution requires more and by having more you also introduce more artefacts. Read any UHD TV review, its unfortunately one floor of UHD TVs.I'm not sure how this works. If I have a piece of A4 paper and colour it red it's a red piece of paper. Let's imagine it's a single pixel. If I cut this paper into four it's four smaller pieces of red paper. The "pixel count" is higher but otherwise it's exactly the same. Same area, same colour. You can keep cutting the paper up but there's no reason why the smaller pieces of paper can't show the same as the larger one.
What then might happen is the extra pixels might be used to make the image better. All things being equal you should get the same or a better image with higher resolutions not a worse one.
What I think happens is that when someone buys a new television they also buy a larger one.
The problem is expanding an SD image over more and more real estate and that is why the image looks worse. People then think new televisions are bad at showing SD or a 4K TV is bad at showing HD. It isn't. It's that you bought a bigger TV and you spread the resolution over a larger screen.
