Best 42" tilting wall mount
Discussion in 'Home Cinema Buying & Building' started by Ponty, Jul 19, 2005.
  1. Ponty
    Ponty
    Feb 15, 2005
    68
    Advice wanted on best value mount with following criteria
    - Secure
    - Easy to install - i.e mount plasma on bracket once bracket is on wall
    - Relatively close to wall i.e. slimline but still allows easy cable management (especially as cables are within wall and short in length etc)
    - Tilting (ideally in fixed position without too much hassle)
    - Good compatability (haven't bought yet, down to last 3 choices)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
  3. Goofy
    Goofy
    Jan 10, 2005
    97
    Leeds
    I can certainly vouch for HD's recommendation - I got my PWD7 from AVsales together with the tilting wall mount. It is very easy to install - 6 x size 12 masonry screws (plus suitable wallplugs) for the back panel is the only thing you will need to get. The wall mount comes with all other fittings.
    You will need to place the plasma (carefully) on a flat surface, face-down, to fix the mounting plate to the plasma with the screws/washers supplied.
    The key thing to success is to use a good 4 - 5foot long spirit level - otherwise the plasma may well tilt the wrong way!
  4. Dave
    Dave
    Jul 3, 2005
    11,493
    163
    +3,401
    I agree. I got one for my PWD7, it's a doddle to install and adjust. Quality and service was top notch too.
