Best 42" for HTPC(Nebula TV & Theatertek)
Discussion in 'Plasma TVs' started by Molly, Jul 13, 2005.
  1. Molly
    Molly
    Jun 15, 2001
    212
    Lincolnshire
    What currently is the best 42"plasma for use with a HTPC running a Nebula freeview TV card and Theatertek showing both DVD and high def films (720p and 1080i)?
    Can I achieve 1:1 pixel matching without aspect ratio problems?
    Will it run at the correct frequency for both Pal and NTSC video?
    Can I connect using DVI/HDMI and achieve the above with no other problems?
    Budget approx £2500.
