Best 4:3 Rear Projection Hi-Def TV, in terms of value, size, quality?
Discussion in 'TVs' started by anandxxx, Feb 23, 2005.
  1. anandxxx
    anandxxx
    Hey. I was thinking about buying a big-screen, hi-def TV (probably rear-
    projection), and I wanted some advice. I'd prefer to get a big-ass 4:3
    model, since it better suits my purposes (video games, anime, old movies, etc.), and the widescreen area should still be more than adequate. I know they don't make many these days, so there must be some good deals on new old-stock models, right? Could you tell me what the best model is, and where I could get it?
    My priorities are, in order: Value, Size, and Quality. Also, I'd like
    something with a lot of flexibility (zoom options, etc.), a good line
    doubler, and a decent variety of inputs.
    Thanks in advance. Later.
    (Is this the right place for this post? And is this forum only people from the UK? I'm from the US, if it makes a difference.)
  2. markymark34
    markymark34
    Dec 15, 2002
    3,241
    Northern Ireland
    +328
    4:3 has really died off here in the uk.
    most people here from this side of the atlantic i think! although i could be wrong.:oops:
    go on put me off my dinner tell me how much a huge TV costs in America?
  3. anandxxx
    anandxxx
    Why, is stuff more expensive there?
    Ehhh, you can get a really nice one for around $1500, I think.
    4:3 has pretty much died off here, as well. That's why I thought I could get a good deal. A closeout, or something.
  4. Laurel&Hardy
    Laurel&Hardy
    I don't think you can get a nice 4x3 RPTV here now so yes, we are ripped off. We get crap 4x3 for the same price you get good ones for. $1,500 is about £800 at the current exchange rate. What model does that buy you by the way?
    Oh, and over here HD inputs are only found on plasma, LCD, DLP or light projectors. No CRT based product has such a feature as DVI or HDMI in the UK at least, I'm sure the same applies to mainland Europe.
  5. anandxxx
    anandxxx
    Oh, I don't know the models. I'm fairly clueless about that stuff.
    As for DVI, etc., I don't know if I even need it. And doesn't it have copy-protection limitations?
