  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
Best 4:3 chip PJs?
Discussion in 'Projectors, Screens & Video Processors' started by FlyingBig, Oct 16, 2005.
  1. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    As PC's aren't native widescreen i would like to sitck with 4:3 to make life a little easier and allow me to run games at 800*600 and even 1024*768 if the projector is that good. Any suggestions? The projector i buy will be used 75% of the time with the PC for games/movies and the rest of its life will be used with xbox/360/PS3. I understand that NED uses 4:3 chips but as it hasn't recieved great reviews its not worth the cash. Any others i don't know about or are all you happy with your widescreen PJs?
  2. xavster
    xavster
    Apr 14, 2004
    439
    +23
    As far as I know, you can set your PC so it IS native 16:9.
  3. DEANO-B
    DEANO-B
    Oct 15, 2004
    514
    Leeds
    No,no,no to 4:3 - Your PC and most games are 16:9 compatable using 1280x720 resolution and nearly every xbox 360 game will be 16:9 hi def. My PC is through the PJ and games such as Far Cry running 1280x720 are absolutely amazing!! :thumbsup:
