Best 37" Plasma
Discussion in 'Plasma TVs Forum' started by ChalkyCardiff, Oct 31, 2004.
  1. ChalkyCardiff
    ChalkyCardiff
    Jul 24, 2004
    326
    +6
    Hi Forum,
    Which models are compatible with HDMI fed via Arcam DV79 and will able to accept Hi Def TV when its more widely available?
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    There arent many 37" about, i think panasonic are the only manufacturers (im sure somone will be able to confrim this though) Do you want a TV (Panny Viera) or just a monitor? (Panny PW7)
    Also whats your budget?
  3. ChalkyCardiff
    ChalkyCardiff
    Jul 24, 2004
    326
    +6
    The intention is to feed in my Sky+ into my Arcam AVR300 which will upgrade the signal into progressive scan. My new DVD will be the DV79 so must be HDMI compatible.
    This will be nearly all sky tv as the intention is to get a projector for movies, hence the need for a smaller screen.
    Budget is not an issue....picture quality paramount!!!
  4. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    You cant get better than a panny for picture quality :) Since you have an amp you wont be needing the likes of the viera in that case, just go for the panel. Head off to www.av-sales.co.uk or some of the other site sponsors to take a look :)
    Not sure about the HDMI side though, as i dont think those input cards are available yet, someone else might be able to fill you in on that
  5. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    bugdet not an issue eh?
    i know you said plasma but loewe launch their all new R37 spheros lcd.
    it has all you want and more!
