Best 36" CRT?
Discussion in 'General TV Discussions Forum' started by Rasczak, Jul 9, 2004.
  1. Rasczak
    Rasczak
    Apr 3, 2002
    21,688
    Warwick
    +2,561
    Hello all,
    I am after a new TV set for the bedroom and have settled on a 36" CRT. The question is which one? The Panasonic TX36PD30 looks good - but does any one else have any suggestions? I need one that can support PAL and NTSC progressive scan inputs.
    I am NOT interested in Philips models as I simply won't touch their products due to quality and reliability issues (I had SO many problems with a Pixel Plus TV...).
  2. FazerThou
    FazerThou
    Aug 23, 2003
    1,893
    Bath
    +149
    Tosh 36zp38 I think is the model number (pic frame model).
    If you do happen to go for the tosh don't take out an extended warrenty with the shop, send off your warrenty card and tosh should offer you their own cover. They did me, an extra 4 years was £130.
    Paul
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,546
    London
    +467
    Bedroom ? Blimey you are going to have a job getting a 36" upstairs ! :D
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,688
    Warwick
    +2,561
    Thanks for the suggestion - I will look into the model.
    House is being refurbished/rebuilt at the moment and the contract requires the company to concern themselves with logistic problems such as this (it shouldn't be that much of a problem!). I am more concerned as to whether the 10mm safety glass on my display stand will be able to take the approx 85kg weight of the CRT.
  5. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    Man i have had some fun and games getting a few 36 inch CRTs up stairs! I don't recommend it! Especially since both tvs had to be returned due to problems, thank god i didn't have to take them down the stairs as i probably wouldn't be around today!
