Best 32 or 36inch TV (Advice Please)
Discussion in 'TVs' started by Marty McFly, Oct 5, 2003.
  1. Marty McFly
    Marty McFly
    Hi people,
    Having browsed around various electronics sites, copying and pasting model numbers into avforums search facility and finding problems with just about every TV I have searched for. Can anyone recommend a GOOD TV capable of:
    o PAL 50/60
    o NTSC (True for R1 DVD imports WITHOUT flicker or picture problems)
    o No buzzing sounds
    o 100Hz (is this a good thing?)
    It does not need to have Dolby Digital or anything truly special but it DOES need to handle NTSC Region 1 DVDs without banding, flicker or other picture problems.
    I have my mind set on a 42inch Toshiba RP but am still debating whether or not it will be visible in this small room, £1k is a lot of money to spend on a TV that might not be usable.
    My budget is upto £1k
    Thanks.
    PS: Sharp 32JF77H (any good) ?
