Best 32" LCD for £500
Discussion in 'LCD & LED LCD TVs Forum' started by kalel vs zod, Apr 22, 2007.
Tags:
  1. kalel vs zod
    kalel vs zod
    Apr 17, 2007
    53
    9
    Just need a bit of advice here. I have been trawling the forums and the web trying to work out which 32" LCD to buy. I have narrowed it down a bit but all the TV's have issues of some sort. Would be grateful for opinions on the following sets;
    Samsung LE32R74BD - This seems to be a good TV but the panel lottery thing is really putting me off.
    Sony Bravia KDL-32U2000 - Could only find reviews of the KDL-32V2000
    Philips 32PFL5522D
    Panasonic TX-32LXD60 - This seems to have very good reviews, there is also the Panasonic TX-32LXD600 which is very confusing
    Samsung LE32T51BX - This is £489.99 at argos but I read it suffers from tearing via VGA
    I was previously looking at the Hanspree XV32 or the Mirai 32" but decided to get a better quality TV. Is there much difference in quality?
    Any advice, links to reviews, links to cheap prices or even recommendations would be appreciated.
  2. chrissyman
    chrissyman
    May 1, 2006
    418
    28
    +33
    well i have just got a bravia 32' S2030 and am very relieved to be honest,
    as my old wega 32 just died and i was not expecting the bravia to stack up too well, but after a bit of tweaking with the settings i now have an excellent picture but it is dependant on the quality of signal/bit rate etc.
    the price was £599 from play.com delivered, but i do like the panny and the phillips you will have to make a choice it may come down to price but the phillips does have 2 hdmi's if that matters.
    stick to your budget i would not spend more than 600.
    one other thing the ps2 looks great on the bravia using the s video feed.
  3. 123381
    123381
    Aug 31, 2006
    9
    3
    Go for the philips
    My budget was tight so i got mine from John Lewis great price free delivery and a free 5 year warranty. have you seen how much comet dixons currys want from you?
    Get a panasonic emr25 and connect the 2 with a decent qualilty ixos hdmi to hdmi cable and the picture and sound will blow your socks off
    I got my panasonic recorder from ebay brand new for £115 make me an offer it has freeview and multi region(saves having a dvd player then a dvd recorder)
    What ever you choose get a on site warranty?
    Puddy
    ps the philips looks good it has small frame in black glass buttons hidden on the side
  4. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    Mirai is a quality set and now, its below £360 with free three year swap-out (manufacturer's) warranty
    If you want something better then all of the above, go for the Panasonic XD600
  5. ash
    ash
    Jun 9, 2005
    11,296
    +396
    I wouldn't go for that Sony you listed, its a very BUDGET model.
    That Pansonic looks good though :)
