Best 32" for under £600?
Discussion in 'LCD & LED LCD TVs Forum' started by makar1, Dec 31, 2006.
Tags:
  1. makar1
    makar1
    Apr 11, 2006
    27
    3
    The options so far:
    Samsung LE32R74BDX
    Toshiba 32WLT66
    I'll be using a separate sound system so sound quality isn't a problem.
    The tv will mainly be used for SD Sky, possibly HD in the future; Wii games over 480p Component; and SD DVDs. Good PC input would be useful as well.
    I've read that the Samsung has motion blurring, but 1:1 pixels for vga; and only has 1 HDMI socket.
    The Toshiba has 2 HDMIs and less reports of blurring but has buzzing problems and supposedly bad vga support.
    Also I might get a 26" version of either tv to save space+money and have a higher dpi
  2. Loobster
    Loobster
    Jan 11, 2005
    639
    28
    +31
    All LCDs have motion blurring.
    If you are going to watch almost exclusively SD stuff then get a CRT - the LCD technology isn't there yet for good SD viewing.
  3. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,146
    Leicester
    +57
    What about Plasma though?
  4. makar1
    makar1
    Apr 11, 2006
    27
    3
    Some alot worse than others.
  5. makar1
    makar1
    Apr 11, 2006
    27
    3
    bump
  6. cozboz
    cozboz
  7. makar1
    makar1
    Apr 11, 2006
    27
    3
    no comments?
  8. Loobster
    Loobster
    Jan 11, 2005
    639
    28
    +31
    Plasma is better than LCD but still not as good as CRT for SD material.
  9. pixelated
    pixelated
    Feb 12, 2005
    1,847
    +94
    But neither Plasma or LCD have any geometry issues. I would say if you're planning almost exclusive off air SDTV like Sky or Freeview, go Plasma without a doubt. Both Plasma and LCD are great for DVDs and of course they can do HD. I'd personally opt for Plasma.
