Best 32" for SD??
oatz
Buying today!
Is it still the 32d3000 and if so, where is the best place to buy one from? As JL don't appear to sell them anymore:(
Nielo TM
Buying today!
S3000 will do the job just fine imo. I can provide the best settings if you wish
oatz
Thanks Nielo, so even though the S doesn't have 100hz (helps with blurring motion flow) it's still good at handling SD for fast moving images ie football?
Cheers!
Nielo TM
I have the Sony KDL-26P2530 with three old panel technology (PVA), and it absolutely fine for watching sport. In other words, the S3000 will do just fine. Just apply these settings
Picture:
Backlight: 5
Brightness: 50
Contrast: 87
Color: 45/50
Sharpness: MIN
Color Temp: Normal/Standard
Noise Reduction: OFF
Color Space: Standard
Audio:
sound Mode: BBE Viva
Bass: 50
Tone/trable: 100
Other:
Energy Saving: Reduce
If I've missed anything, let me know
vickster
Are those settings good for the 26T3000 too? :)
vickster
Thanks. I only have a scart lead and no HDMI - and a crummy booster plug in set top aerial until the Virgin is fitted on Saturday (normal not V+ box) Assume the settings still go? :)
Nielo TM
I couldn't find the following highlighted on the 26T in the menu?
Picture Adjustment:
* Mode: Custom
* Backlight: 5
* Contrast: 87
* Brightness: 51
* Color: 45
* Sharpness: MIN
* Color Temperature/Tone: Natural
* Color Space: Standard
* Noise Reduction: Off
Sound Adjustment:
* Sound Effect/Mode: BBE Viva
* Treble: MAX/100
* Bass: 50
* Auto Volume: Off (user preference)
Features:
* Power Saving: Reduce
* Advanced Contrast Enhancement (Backlight Dimming): Off
That's because you have to switch the picture mode to custom
On the remote, find the button that controls the picture mode. It's next to the sound mode.
If your remote is similir to mine, it should be near the top
vickster
My set appears to have only vivid, standard and cinema in picture mode
Nielo TM
or sorry
Go to settings > highlight picture mode > press right or ok and you shoud see a drop-down menu
vickster
Yep, done that ... just those three settings ...we are a little :offtopic: now
Nielo TM
ya we are lol
But you shoud get all the options. When I got mine, I had the same issue, but I managed to change it to custom.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
