Best 32" / DVB TV
Discussion in 'General TV Discussions Forum' started by Michael Belej, Jul 3, 2001.
  1. Michael Belej
    Michael Belej
    Dear Experts
    I want a 32" TV with best picture quality. Sound will be via seperates. Any ideas?
    Also, should I be looking for a set with a DVB logo - is the quality better than a set top box. Recommendations please. :rolleyes:
  2. PJONG
    PJONG
    Oct 7, 2000
    87
    London
    Mike,
    You might want to check out Philip's 32DW9625 which has an onboard Ondigital decoder , one less box under the telly. I came across it in John Lewis, very nice picture (100hz). I'm in the same boat as yourself and most people, what 32" widscreen to buy? The biggest headache I've found is deciding between 50 and 100hz. In the end I'm going for a 50hz Panasonic, at this stage I'm not so sure that 100hz technology warrants the extra 2 or £300
    Phil
  3. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    if its a 4.3 picture you want take a look at loewe "they make a callida which i think is the best picture ive seen ,i spent £3000"in the past" on a b&o but it sucked compared to the loewe .i think they are about £1200 now .awsome picture if its tv rather than films you like :) :) best move i ever made
    pic here on my site http://www.ronin100.pwp.blueyonder.co.uk///
    [ 04-07-2001: Message edited by: leon ]
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Easy Answer a Sony IDTV.
    Very good picture - better than a box, only get 100Hz if you are suspectable to flicker.
    I have got a KV32DX20 - a very good TV
  5. simes
    simes
    Why pay extra for a DVB TV ?
    The digibox comes free with your subscription.I agree its nicer to not have another box under the TV but to pay so much extra for the privilidge is crazy.That is unless you only want the free channels ;)
  6. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The Loewe Aconda is a great TV, with the VGA option you can use a HTPC to watch DVDs at 848x480 progressive scan. It also has 2 RGB enabled scart sockets (the 3rd supports upto svideo). One of the scarts also supports component video. You can easlily access the service menu to correct any geometry problems. It supports PAL60 regardless of the DVD player. Picture quality is great and for a 100Hz TV it is great with fast moving sports such as football. When you turn it off it does this very cool closing curtins effect. There isn't a TV in the world that I would swap mine for and I have had it for over a year.
    Jeff
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Sony DVB tuner gives a better picture than a loan Ondigital box!
