P
panduru
I have to make a choice between these 4 TV's:
Panasonic TX-32PS12P
Philips 32PW8751/12
Philips 32PW9551/12 (is the newer and more expensive Philips better than the old model and if it that's the case is it worth the extra pounds?)
Sony KV-32CS70
I read on this forum complaints about some poping sounds from Philips tubes. Are they really a common problem?
What issues do the Sony and Panasonic have?
It will be mainly be used for SD on cable TV and DVD movies.
Which one of the above has the best picture clarity without appearing overprocessed?
Thank you.
Philips 32PW8751/12
Sony KV-32CS70
Thank you.
