Answered Best 3 / 4 tuner, freeview and catch up, TV recorder?
VisionMan
If I may ask - If you find a box with 3 or 4 tuners, when are you going to find the time to watch them all? :(
grahamlthompson
In memoriam
I was considering the Humax FVP 5000T but it has some terrible reviews.
Any recommendations appreciated?
Afaik the Humax FVP boxes are the only ones that can record up to 4 at once.
A new multituner Freesat PVR is due out this year from Arris. The original info appears to suggest that it will have similar multi-recording capability as a Sky-Q box.
VisionMan
And being new will probably cost a fortune. Not that FVPs are that cheap either.
cc120, have you considered getting 2 boxes? Or Cord Cutters suggestion above of using Plus+1 channels? Mind you, that would depend on the channels you want to record.
cc120
Doesn't freesat require a satellite dish?
cc120
Hi VisionMan. When you say 2 boxes do you mean 2 recorders? Replied to Cord Cutter re: Plus+1.
cc120
I am now considering Panasonic DMR-HWT150EB versus Humax HDR-FOX T2? Each has 2 tuners. The only 3 / 4 tuners available it seems are the Humax 4000 and 5000. Both have many bad reviews.
Humax HDR-FOX T2 has more catch up options than the Panasonic DMR-HWT150EB. Are there any more pros / cons for either?
grahamlthompson
In memoriam
How do you use more than one recorder on one TV?
You just connect them to seperate HDMI ports on a TV. You use the TV remote to select the hdmi port that the box you want to use is connected two.
It's a lot easier with a AV receiver as you connect all your kit to the AVR HDMI in sockets and the AVR to the TV with a single HDMI cable.
Humax boxes have multiple IR modes for theie pvrs so you can have more than one in one room and use multiple remotes without them clashing.
grahamlthompson
In memoriam
Basically a HDR-FOX-T2 only has iplayer.
grahamlthompson
In memoriam
Thank you grahamlthompson, so would you recommend the Panasonic based on that?
No experience of using that box. Sorry.
cc120
I think my new TV only has 1 x HDMI socket so would have to go the AV receiver route.
Buying more than one Humax recorder would be expensive?
Ensor
Unless you need all the features of an A/V receiver, you could just get an HDMI switch box.
grahamlthompson
In memoriam
Thank you grahamlthompson. So with this unit I would plug in my TV, and two separate recorders, eg: 2 x Panasonic DMR-HWT150EB or 1 Panasonic and 1 Humax HDR-FOX T2. So that either would access the TV and record, thus offering 4 recording channels?
Correct. You would of course need to connect both to your aerial. A simple aerial splitter is likely all you need.
cc120
Thank you again grahamlthompson. Would a booster be required if I split the aerial?
The Toshiba 49L3863DB (specs Toshiba Tv 49L3863DB - 49" Toshiba Full HD WLAN TV) was unsuccessful connecting via wifi, I guess I will I need to cable it to my router which is down the hall ?
If I have catch up tv via Toshiba, will I not need it on the recorder?
grahamlthompson
In memoriam
You would only need a booster if your existing signal is weak. When the analogue TV system closed down the power output of digital TV transmitters was increased much more than the signal loss (approx 4dB) created by a one in two out splitter. Ideally use a metal one with f connectors.
eg
Wideband TV & Satellite Splitter 2 Way
cc120
eg
Thank you for your patience grahamlthompson.
As the wifi connection on the Toshiba 49L3863DB didn't work, I will try connecting via cable to router to enable me to access 'TV catch up' facility.
If the attached recorder has a TV catch up facility, would I also need to cable it up to the router separately?
