solosheep
Hello Guys
I have had to sign up as new users as I have lost my old account
I hope you can help. I’m looking for some smart light switches and I have had some success with Sonoff units which are 1 way.
However, when it comes to 2 way switches this is where I have some issues. I would like them to work with ALEXA and I don’t have a Broadcom or other hub so ideally, I would like them to work of EWLink or SMART LIFE etc.
Most of the house which I’m looking to use the smart lights are wired to have neutral apart from one socket. I have included photos of the light sockets below. I’m also looking for switches that would cover the hole left by the 3 gang rocker switches.
I hope you guys can offer advice on which units I would require. I would like a straight swap to allow the switches to work even with loss of WIFI. Also, if it’s too expensive to do all the lights I would look at only doing the 1 4 gang unit and the 2 3 gang units.
Hope it makes sense
Kitchen switch (4 gang)
Hall light on the same level as Kitchen
Landing light
Landing light 2 – No neutral in this slot have looked at installing the below unit (which is on order)
Yoswit Smart Light Switch 2 Gang - No Neutral Wire Required, Control Lighting from Anywhere, No Hub Required, Built-in Timer and Support IFTTT
Attic light
Hope it makes sense
Landing light
Attic light
