Best 26" for Xbox 360 and PC use?
Discussion in 'LCD & LED LCD TVs Forum' started by MacUK, Jan 2, 2007.
Tags:
  1. MacUK
    MacUK
    Hey All
    I am after a new LCD that will be used mostly for Xbox 360 and PC, it will also have a SD sky box attached but it will be rarely used so i am not going to be too upset if this does not look A1. I am thinking along the lines of the samsung R7 range but dont know if there are problems with PC on this one like there are on the Tosh WLT66 range.
    If anyone knows of any sales or online retailers i can check out i would appreciate it. I am aware of one good one called digitaldirect.co.uk but they dont seem to do 26" or samsung so any other suggestions?
    Many thanks :)
    Marcus
  2. Mattyboy_W
    Mattyboy_W
    Jan 13, 2005
    122
    +4
    Just bought a Samsung LE27S73BDX which works very well with PC and XBOX. Hispek.com have them for £499.
  3. matt1
    matt1
    Dec 30, 2006
    47
    +3
    I'm in a very similiar situation, I've currently got a 17" LCD monitor which I only use for my PC. I've just got a Wii and need a TV to play it on really, I've kept my eye out for a bigger LCD monitor anyway so I've been looking to satisfy both in one go. I've heard it's a compromise on both parts, i.e. a LCD TV not acting as well as a LCD monitor when used on a PC and vice versa when used as a TV. The WLT66 pixelmapping is also an issue I've come across, but looking at this it seems it will do it over a DVI->HDMI cable. But perhaps other LCD TVs would function better as a monitor, my only issue with the Samsung is poor sound. I'm quite tempted to go for a cheapest 26" now, such as the Hanns G which some companies like OcUK and Dabs do an ownbrand version for ~£340, but when you consider the Toshiba and Samsung 26"ers versions now selling at £499 it's a difficult choice.
  4. Raven1907
    Raven1907
    the real issue is with using tv's as pc monitors at less than 4ft viewing distance a 26" 1366x768 is horrible, you can see each individual pixel, hence why i'm getting the benq when it hits £600
  5. Se777eN
    Se777eN
    Dec 28, 2006
    8,711
    2
    Southport
    +2,336
  6. MacUK
    MacUK
    Thanks all
    Will shop around for one of these puppies over the next few days. :)
    Marcus
  7. Scen3
    Scen3
    Aug 5, 2006
    158
    Glasgow
    +5
    Does anyone here know if Sony 26 KDL26U2000U is a good buy for £399?
    It will be used for gaming and PC too.
  8. daddyorchips
    daddyorchips
    Dec 12, 2004
    1,080
    63
    London
    +95
    I'm thinking of ordering an LE26R74BDX as a secondary screen, mainly for 360 use. Does anyone know if the backlight is alterable when running over VGA? (I believe it's called Energy Saver mode on this set) The Samsung's predecessor - the LExxR41BDX - didn't have this option whilst using the VGA input...
  9. Tezcatlipoca
    Tezcatlipoca
    Jan 2, 2007
    139
    +9
    I got a Samsung LE26R73BDX last week (Currys/Dixons/PCWorld version of the R74).
    Currently using it for my 360 (component) & SD Sky (RGB SCART).
    I love it.
    Price comparisons & reviews for the LE26R74BDX at Pricerunner: http://www.pricerunner.co.uk/sound-and-vision/vision/tv/586528/prices
    It's had 5/5 reviews with What HiFi, Stuff, Computer Shopper & others.
  10. TheWasher
    TheWasher
    Jan 2, 2007
    96
    Hey Aqib,
    Where you seen this for £399? could you PM me please?
  11. matt1
    matt1
    Dec 30, 2006
    47
    +3
    Have a look at another one of his posts here. I'm quite interested in this too, now the LE26R74BDX can be had for £472 I'm unsure, heard that U Series Sonys aren't great. wiki indicates it won't do 1:1 on a PC using 1366xxxx, totally :rolleyes: now.
  12. Ja50nKay
    Ja50nKay
    Jul 23, 2004
    894
    46
    Bournemouth
    +181
    I'm loving my LG 26LC2R
  13. dan54
    dan54
    Mar 27, 2006
    1,261
    63
    +107
    Told you it was good Mr Kruys:D
  14. stuart_haydn
    stuart_haydn
    Feb 20, 2006
    206
    Slough
    +7
    I don't know about the U series - I have the S series (KDL26S2010) which I highly recommend. I think there is now a version with an all-black casing. The Bravias as more expensive than the Sammy R series - but definitely better if you can afford it. You get significantly mroe customisation options on the Sony.
  15. mho64
    mho64
    May 13, 2006
    393
    +5
    I also have that the Sony 26" S series and have used it for both pc and xbox 360. Cant fault it, definately recommend.
  16. BRUCE182
    BRUCE182
    Jan 9, 2006
    137
    +3
    That's plus VAT.....
  17. paullord
    paullord
    Dec 30, 2006
    24
    3
    If it is true that Makro have them it is still way cheaper than anyone else even with the VAT....£468.83
    Or even cheaper, http://www.andreas-electronics.com/home.php?cat=264 have the Sony 26 KDL26U2000U on for £357.10 after 30% voucher discount(AE817QW), but I wouldn`t recommend them !!
  18. Se777eN
    Se777eN
    Dec 28, 2006
    8,711
    2
    Southport
    +2,336
    went to order Samsung LE26R73BDX from 247 elec sold out like many other places anyone else know where i can get it for 471 pounds?
  19. daddyorchips
    daddyorchips
    Dec 12, 2004
    1,080
    63
    London
    +95
  20. stu.artd
    stu.artd
    Jul 29, 2005
    3,895
    +333
    Like a couple of other replies I also have a Sony 26S2010. I use it with my 360 via component, PS3 via HDMI and PC as a secondary display through VGA.
    I'm very happy with the TV and have had it since March last year.
    Some old test photo's of it in action with both X360 and PC below, took them ages ago but they should give you an idea.
    X360
    [​IMG]
    [​IMG]
    PC
    [​IMG]
    [​IMG]
