best 23" LCD for x box 360????
Discussion in 'LCD & LED LCD TVs Forum' started by add46.88, Aug 28, 2005.
Tags:
  1. add46.88
    add46.88
    Aug 28, 2005
    975
    +22
    What 23" LCD do you recommend for the XBOX 360?Ive been looking at the samsung le2341b,is that any good?I dont want to pay anymore more than £650.High definition gaming is what its all about!!!
  2. peahead
    peahead
    Dec 14, 2002
    2,991
    St.helens
    +375
    Hi add46.88
    The new samsungs are rated highly on these forums why not go for the 26" version it can be had for under £600 and has a hdmi input for futureproofing.
  3. add46.88
    add46.88
    Aug 28, 2005
    975
    +22
    Do you think the 26" is a suitable size for the bedroom?I have seen the samsung LN-R238W which seems perfect but ive only found it on american websites.Should i maybe wait for the new sony LCDs?
  4. peahead
    peahead
    Dec 14, 2002
    2,991
    St.helens
    +375
    The sony screens use samsung panals anyway.
  5. andrewfee
    andrewfee
    Apr 27, 2004
    3,061
    +500
    I'm not sure if that's the case with the latest ones, they seem to have different specs. The latest samsung is 1000:1, 8ms, 178º viewing, wheras the new Sony's are 1000:1, 8ms (apparently) and 170º viewing angle.
    They use a much better panel driver though, which can make a difference to how a panel performs.
  6. Moogle
    Moogle
    Aug 28, 2005
    13,749
    London
    +1,398
    I believe that is the US version of the European LE23R41B all be it with a few minore differences. I was looking that the US version of the LE26R41B and it has two components instead of one probably because the US models don't have scart. It's a shane as I'd rather have more component inputs at the expense of scarts.
  7. add46.88
    add46.88
    Aug 28, 2005
    975
    +22
    Anyone no if the JVC LT-23D50 is any good for XBOX 360?.Will i be able to play in HD on this TV?
  8. Adam_uk
    Adam_uk
    Aug 27, 2005
    1,900
    Newbury
    +94
    will the X -box 360 and the PS3 both have HDMI connections?
  9. peahead
    peahead
    Dec 14, 2002
    2,991
    St.helens
    +375
    Yes it will work with xbox 360.
  10. peahead
    peahead
    Dec 14, 2002
    2,991
    St.helens
    +375
    xbox 360 wont have hdmi at first but it is compatible just needs someone to produce a lead for it and ps3 will have hdmi form the off but thats a long way way way away.
  11. Theriomophic
    Theriomophic
    Aug 9, 2004
    138
    +6
  12. V3X
    V3X
    Jun 14, 2005
    255
    +14
    Hi all,
    I'm also having a hard time deciding which LCD to choose for my gaming with 360. I also thought about purchasing the samsung but was put off with all the reported tearing problems. Is this TV safe to use with 360 or is it worth waiting for the new sonys to avoid the tearing?
  13. JayHarkin
    JayHarkin
    I was very interested in the Samsung, but all this tearing scared me right off. I am now looking towards the Sharp LC32GA6E, looks a beauty and is competively priced under a £1000.
  14. add46.88
    add46.88
    Aug 28, 2005
    975
    +22
    Can someone recommend me the best dvd player to buy for my samsung le2341b?I really want the best picture quality possible...
  15. Branxx
    Branxx
    Nov 1, 2000
    801
    London, UK
    I think it would be difficult to beat xbox 360 on DVD quality. why spending money on something inferior?
  16. JayHarkin
    JayHarkin
    I really think Microsoft has a big hit on there hands with the 360, its the talk of the town.
  17. add46.88
    add46.88
    Aug 28, 2005
    975
    +22
    My mate said i might no be able to play xbox 360 in HD on my samsung le2341b!.Can someone 100% confirm that my samsung le2341b will play games in high definition???Please answer fast im getting nervous....
  18. peahead
    peahead
    Dec 14, 2002
    2,991
    St.helens
    +375
    Yes you will be able to play xbox360 in hd on your samsung it accepts hd through it component inputs or its vga input whichever you chose your mate must be pulling your leg. :smashin:
  19. add46.88
    add46.88
    Aug 28, 2005
    975
    +22
    Thanks peahead :) my mate got me worried for a minute!
