Higibuilder
Hi all
What are the best budget balanced cables .
Need 1.5 or 2 mtr
Many thanks in advance
Need 1.5 or 2 mtr
What equipment you have and what budget you have would be very helpful in making recommendations
Hi thanks for the help guys
Looking at going balanced between my primare pre and new Parasound halo a21 amp
Need cables ether way so thought balanced would be the way to go . Have around £75-100
To play with even used cables if I'm going to get the extra quality
Thanks rob
What's the benefits if any over them with these 2 please .
Great thanks only looking at the litz wire as wasent sure if silver would make a better conductor for the cable .
If the basic cables will work just as well I may as well give them a try . Also if the cables from desighn a cable look good enough is it worth spending extra on better xlr ends .
Many thanks
I would not buy the ones on the left because it does not look like they have any shielding? Also way too expensive. While the principle of balanced cable reduces pick up and noise through common mode rejection it is always better to have the the audio wires shielded - you know belt and braces.What's the benefits if any over them with these 2 please .
Just bought second pair . So impressed and can't believe they sell for peanuts .
Did you find the cables got better after burning in .They are amazing value aren't they, the build quality is first class as is the sound quality.
I don't know how they can sell these custom cables made to order for the price.
Cables don't get any better than these .
