Best 17" or 19" TFT Monitor for under £120?
Discussion in 'Desktop & Laptop Computers Forum' started by badlydrunkboy, May 6, 2007.
  1. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    I'm looking for a new monitor to replace my 19"CRT one because I have to move it about preety often and the CRT weighs a ton. What is the best monitior you can get for under £130?
    Will be used mainly for surfing the net, Football Manager, Counterstrike and C&C3. My graphics card is a Radeon X550XT if that makes and difference.
  2. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    Are you looking for one with DVI, or are you not bothered? There are some good value analogue monitors at that price point.
  4. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    I dont really know the difference to be honest. I know my graphics card has 2 outputs that are different shapes and sizes. Which is best?
  5. ash
    ash
    Jun 9, 2005
    11,296
    +396
    The DVI (digital video) is this one on the far right:
    [​IMG]
    The other one is VGA (analogue video).
    Some people notice the difference, others don't. Tough one really. I've only ever had VGA TFT LCD monitors.
  6. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    My current monitor has one of those connections, as does my TV. Maybe I should look for a digital one then. Any recommendations?
  7. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    Also, my graphics card doesn't seem to have a 1440x900 (or whatever it is) option so does that mean a widescreen monitor wouldn't work? Was hoping to connect the PC to my LE32R74BD but i guess that wont work either as its widescreen?? :(
  8. paul9619
    paul9619
    Jan 4, 2005
    605
    +21
  9. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
  10. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    Personally I think that's quite expensive for a 4:3 19". I'd spend a bit extra and go for a 20" or 22" widescreen.
  11. nwgarratt
    nwgarratt
    May 5, 2002
    27,785
    +3,190
    I use this monitor. I apid £120 but it is now £110.
    http://www.amazon.co.uk/HANNS-G-HC194D-1280x1024-resolution-response/dp/B000G1T1GW/ref=pd_bbs_sr_2/026-0490530-2734832?ie=UTF8&s=electronics&qid=1178753931&sr=8-2
    I don't like 19" widescreen monitors. The big resolution makes everything too small and hard to read. I wouldn't go under 22" if I had a widescreen one.
    That isn't that expensive for a Samsung. I paid £500 for a Samsung 17" before that HannsG one.
  12. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    The amazon price is good at £160, especially the cheapest other price I've seen is play.com that are doing it for £200. However, personally I'd spend a bit extra and go for a widescreen monitor. It depends what you are using it for I guess.
  13. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    I'm really stretching the budget to get to £160 (although there is a refurbished one on amazon for £102) so i really cant go to £200. I dont think I'm too worried about widescreen as my TV will be in the same room. Its would also go with the rest of my set up as it's all samsung.
    I'm not sure if i see any real advantage in widescreen monitors.
  14. nwgarratt
    nwgarratt
    May 5, 2002
    27,785
    +3,190
    I don't see the point in widescreen monitors unless DVD's and widescreen games are being played. I use a projector and widescreen TV for DVD's and don't play games anymore.
  15. jaydee999
    jaydee999
    Feb 15, 2005
    243
    SW London
    +13
    The point about widescreen monitors is that if you use spreadsheets, you don't need to scroll across as much, if at all. And you can get more tabs visible in your firefox browser. I find it better just for that.
    jaydee
  16. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    well fellas, I bought the Samsung one. i know it was over my price limit but it just looks so damn good so I sold £100 worth of car stuff to make myself feel better about it :) Cant wait for it to arrive! Gonna be posted to work next week though but i'm on jury duty. I'll have to make a special trip to get it :(
  17. mjn
    mjn
    May 24, 2001
    24,304
    Herts, England
    +13,048
    Are you going to promote www.ishift.co.uk in ALL of your posts?
    Could you be the owner of iShift by any chance?
  18. nogg
    nogg
    Mar 21, 2004
    268
    +12
    And how does it improve the use of websites?
  19. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    They are also great for having more than one window open at a time, without having to task switch between apps. The benefits of two monitors in one!
  20. bigmondy
    bigmondy
    May 4, 2004
    475
    Strathblane
    +6
    So would you surfers with a TFT less than 20" say that you dont notice much difference in PQ with the wide-screen?
    I like the idea of being able to read the tabs on firefox when following a lot of links.
    I am in the market for something around 20" Widescreen and dont have much more than £150 to spend.
  21. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    If you want a widescreen for that sort of money have a look at ebuyer. They've got quite a few on there and most have reviews too.
  22. bigmondy
    bigmondy
    May 4, 2004
    475
    Strathblane
    +6
    Tks for that - willco!
  23. bigmondy
    bigmondy
    May 4, 2004
    475
    Strathblane
    +6
  24. Tommy Vercetti
    Tommy Vercetti
    Nov 12, 2006
    108
    +4
    I bought a Samsung WS 20" with 5ms recentley & I have to say that I didnt notice any difference between it thru DVI & the previous LG 17" LCD I had that was 2 1/2 yrs old & had a response rate of 16ms running thru VGA. The Samsung had both VGA & DVI ports so I used the VGA for my XBOX 360 & it was blurry & had some ghosting.
    I was pretty dissapointed considering all the positive reviews its been given.
    Samsung LCDs are overated. Just get what u can afford & dont pay for anything that u dont need. Although apparently a lot of the cheaper LCDs are just as good as the pricey ones as they are made in the same factory.
  25. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    bigmondy - If you don't mind an analogue screen then this 19" widescreen may suit - great value too!
