Best 1080p LCD for Wii and 360 -Lag Free!
M
mrcore64
I'm lookin for a 1080p panel for around £1500 that I could play my wii and 360 on without having to suffer the effects of Lag from upscaling... Any recommendations?
Cheers:D
I think you'd be hard pressed to find an LCD TV now that has delay from upscaling - it's instantaneous from what I gather.
Deinterlacing on the other hand may have a tiny delay, but with almost all Wii games and all Xbox 360 ones supporting some form of Progressive display, you shouldn't have to worry :)
M
mrcore64
Cheers for that,
I see you got a Bravia, do you notice any Lag when playing 480p games on it? I was leaning towards getting a sony KDL40w2000, but I've heard some horror stories about all Bravia's suffering from bleeding backlights and cloudy patches. Do you notice any with yours?
I'm considering a 40W as well and am put off by the cloudy backlight problem. My 32V's backlighting is perfect and no, no lag at all on 480p or 480i.
Khearts
Cheers for that,
All Bravia's? Even the x series? I wanted to get 1, for my ps3 and x360.
Plus the x series on sd looked great. What else could I go for?
messier0101
In defence for Bravia, there are quite a few of us who have bought the W range and have had a near perfect set, i.e. no dead pixels and very little back-light bleed. I for one can't notice it at all when watching something that is very dark. :thumbsup:
edit> for example Planet Earth yesterday, it had some scenes which were more or less comletely black.
BYF
what do you mean by lag?
do you mean unadded motion blur during fast panning scenes?
i don't know of any LCD that doesn't have motion blur during fast pans.
Khearts
How about motion blur, cause I would be using it for games alot.
Khearts
If you can wait for around 2-3 weeks, I plan to get a a 360 then, I'll tell you how it goes.:D
Otherwise everyone on the W2000 thread seem very happy indeed with their 360.
sweet.
So what else problems are there suppose to be?
I went and saw the 52" x series, looks quite nice.
DD3
the W is the only sony that supports full 1080 over vga and even then thats unofficial support, so if it doesnt work you wont get support.
sharps would have been worth a look, but too many problems with banding and again no 1080 support on anything but hdmi.
You could consider the samsung F series at your budget and also many have found the gtvl42w1dhd a good option too for £900 (if you can find one), both do 1080 on vga and component, otherwise, may be worth waiting for the next wave of 1080 displays to come out.
Crafty
Banding only on 46" sets and it appears that some are coming through now that don't have any...
ReZeN
i believe that mrcore64 is talking about signal lag. where there is a lag between the console's output and the actual showing of it on the screen.
Guitar Hero II has an option to sync up with laggy tvs.
Though I thought most technologies now (LCD, Plasma & beyond) lag and there isn't really anything being done in this area?
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
