Best £600 ish 32" LCD
PAUL_M01
Hi, i'm looking to but a 32" HD LCD.
Other than normal uses, i also need to connect it to my PC whcih has VGA and DVI out.
A few hrs looking has found these matches. Are there any other i should be considering?
Which is the best 32" in my price range?
Vistron VIS032HDID
Hyundai Imagequest A321
Hyundai Imagequest Q321
Relisys RLT32AB50
Viewsonic N3260W
Medion 32" HD Ready LCD TV - MD20099
At the moment i'm very tempted by the Q321 as i've just found it at the same price as the A321. Crazy as its a higher spec??
dickst3
yeah, you'll get a Sony or Panny for around £650. Try Sound and Vision or Dixons online.
samjpullen
The Q321 isnt higher spec, true it has Digital but apart from that the A321 is the higher spec, it uses a newer panel (the same panel that is use by Samsung and Sony) has a higher contrast ratio (1200:1 vs 1000:1) and lets not forget the A321 has HDMI not DVI like the Q321.
Depends if you want the Digital, but if you don't i would go for the A321.
