Bman
Established Member
Hi, I just ordered the w2700 to replace the w1070 projector that I'm using for the last 5 years.
The distance between my floor and the ceiling is about 3 meters, and up until now, the w1070 was installed very close to the ceiling, so I had you use keystone to align the image.
So at a distance of about 1.7 meters above my head, the fan noise of the w1070 is still noticeable in quiet scenes, but I learned to live with it.
For the w2700, I thought of lowering the projector a full meter down, in order to avoid using the keystone, but I'm afraid that the fan noise would be unbearable.
Does anyone else had this dilemma and would like to share his thoughts on the matter?
