Benq w1700
Discussion in 'Projectors, Screens & Video Processors' started by langers2011, Mar 14, 2019 at 9:24 PM.
  1. langers2011
    langers2011
    Nov 19, 2018
    12
    4
    Banbury
    I'm having an issue with my new projector, benq w1700.
    When I start content from sources the image seem to be fairly blurry, then a few moments later sharpens up. It is across different sources, Amazon prime, Netflix, mkv files.
    Just looking for any advice, or if I just have a duff one.
  2. Nayfne
    Nayfne
    Feb 3, 2013
    4,609
    5
    3
    north east
    +10,587
    If streaming, it just sounds like the image is buffering until it gets to the correct resolution? Does this on my Netflix on the tv and projector, depending on how strong the Internet signal is at the time I guess.
  3. langers2011
    langers2011
    Nov 19, 2018
    12
    4
    Banbury
    I thought this. But some shots are crisp and some aren't . Then it's all fine again.
    It seems very different to how the last one did it when it was buffering. But perhaps that's just the fact the image quality is so hugely different.
