BenQ W1400 Reviewer's Recommended Best Settings
Steve Withers
Disclaimer: The settings below are supplied for information purposes only. We make no guarantee that using the adjustments below will improve your TV's picture, they may even make it look worse. Every TV, even from the same manufacturer and model number will vary, as will the environment the TV is used in. For further information on how to set up your TV, please follow the steps in our Picture Perfect campaign.
To find a professional calibrator near you, see our Custom Installer and Calibrator Directory.
You can read the review here: BenQ W1400
Preset Mode: User1
Reference Mode: Cinema
Brightness: 50
Contrast: 50
Colour: 50
Tint: 50
Sharpness: 1
Flesh Tone: 0
Colour Temp: Warm
Frame Interpolation: Off
Lamp Power: Economic
Advanced
Clarity Control: 0
Colour Temperature Fine Tuning: Red Gain 94, Green Gain 86, Blue Gain 99, Red Offset 256, Green Offset 256, Blue Offset 256
Gamma Selection: 2.2
Brilliant Color: Off
Colour Management: Red - Hue 44/Gain 50/Saturation 50, Green - H 56/G 50/S 50, Blue - H 50/G 50/S 50, Cyan - H 50/G 50/S 50, Magenta - H 57/G 50/S 50, Yellow - H 50/G 50/S 50
Display
Aspect Ratio: Real
BoilingFrog
HI, I have been struggling with blown out blue tinted highlights in dark scenes for a while. Having had previous issues with dirty colour wheels and sensor I once again dismantled, cleaned and reassembled the unit today. Still had the blown out blue highlights. However, having reset the pcture following your settings here the picture is great. Thank you for posting this and for it still being available 5 years later.
