Hi.
I've bought BenQ W1210ST / HT2150ST recently and I've noticed that one of fans is not starting with the projector. If you look on a standing projector from the front it's the right fan (if it's mounted on a ceiling it's the left fan when looking from the projector front). Other fans are working, this one does not.
If I switch to high altitude mode for a second the fan start immediately. It even started once when my projector had been working for quite some time. So it looks like there is nothing wrong with the fan itself. Maybe it starts only when it's super hot? But I'd like to be sure. Is it normal that this fan does not start with projector and sometimes, even after few hours is still not moving at all?
If any of you have the same projector (BenQ W1210ST / HT2150ST) could you please check if it's normal behavior?
Thank you.
Thank you.
