Hi can anybody help Benq W1070 tell me where I can buy the main cooling fan as it powered off and when starts up cuts off after 5mins I have cleaned all fans also changed bulb .Thanks
You can check with their customer service team and they should be able to offer the cooling fan and also help diagnose what may go wrong with the your projector.
Is it a genuine bulb the one you used to replace the original with?
My first replacement was incompatible and switched the projector off
Used to be a w1070 owner
